Overheating at idle
Old Feb 14, 2012 | 10:05 AM
pete5956's Avatar
New Member
Question Overheating at idle
HI I'm new to the forum and was wondring if anyone can help me with an overheating problem?
I have a 95 f3 which overheats at idle, it will slowly get hotter until the coolent spills out the overflow on the expansion tank! I have removed the thermostat and tested it opens and closes ok, theirs plenty of antifreeze, and the fan kicks in about 1/2 way on the temp gauge, but the temp gauge goes no higher than inbetween 1/2 and 3/4!
any help would be geat!
Pete
Old Feb 14, 2012 | 11:10 AM
74demon's Avatar
pressure check your radiator cap. it's gotta hold pressure.
Old Feb 14, 2012 | 06:05 PM
Hootie233's Avatar
I had the same problem, go to a auto parts store and get a early 90s honda cap as long as its 1:1 I think thats what it says on our caps right?
Old Feb 14, 2012 | 06:12 PM
74demon's Avatar
1.1 kg/cm3 (16lbs or 108kpa) bring the cap with you, they can match it up. that will save you the extra trip when they give you the wrong one.
Old Feb 14, 2012 | 06:13 PM
estate4life's Avatar
February 2012 ROTM
+1Sir Demon...you are always hitting the bulleye!!!!
Old Feb 15, 2012 | 04:13 PM
pete5956's Avatar
New Member
Thanks guys, it did turn out to be cap in the end!
SPR-GRN
May 7, 2012 06:08 PM
Jrector
Oct 14, 2010 05:28 PM
LJ Harp
Oct 9, 2010 11:03 AM
Rozon
Sep 24, 2010 05:40 PM
sk8runeg
Jun 30, 2006 03:42 AM
