Oil light!!!!
Hi, I just changed my oil and filter on my 96 600. I put about 3.7 qts. of Mobil full synthetic in. when I started the bike up the oil light stayed on. I only ran it for about 10 second before I turned it off. Does it usually take longer than that after an oil change?
The light should NEVER go on. It's a pressure sensor, so your oil pressure is low. Check the obvious stuff first. Is everything tightend down securely? Does the oil reach an appropriate spot on the dipstick measure?
DON'T use the bike until you figure this out, as you're risking severe engine damage.
Honda reccomends using Honda Synthetic 4-stroke oil with the CBR600 F3, so i'd have to trust their judgement on that.
ok, I didn't pre fill the new filter but I started it up again for another 10 seconds and it still didnt go off. Could It be the oil that is making this problem...... this is the first time I am putting synthetic in the bike since I got it. its got about 20,000 on it
