Noise after rear tire change
Old 06-24-2008 | 11:24 AM
Windsock209's Avatar
Default Noise after rear tire change
I changed out my rear tire and since then I have a swooshing sound that is not the chain or tire rubbing on anything. I think my chain tightend up on the firstride post tire change. I reset the chain but then the sound started. The tire is tracking straight and wearing correct. What have I missed? Did I damage the front gear on the transmission?
Any assist would be appreciated!
Thanks!
Old 06-24-2008 | 11:48 AM
ta8218's Avatar
Default RE: Noise after rear tire change
Sounds like brake noise.
Old 06-24-2008 | 12:57 PM
Northernfirepower's Avatar
I can't type my respoince so your SOL till the damn forum is straight
Old 06-24-2008 | 01:13 PM
rider0033's Avatar
try taking a tape measure and measuring from the center of the swing arm pivot bolt to the center of the axle. measure both sides and make sure the numbers are the same. could be slightly off making the noise. and make sure you have i believe an inch of play in the chain
Old 06-24-2008 | 05:02 PM
Ayres_08's Avatar
Maybe your bairings are bad. Mine are, ordered a front and rear kit for 45$
Old 06-24-2008 | 08:59 PM
neely321's Avatar
Yeah try to repack your rear bearings. Ayres could be onto something they may need to be replaced.
600F4inoober
07-17-2011 12:13 PM
cbr600f4i13
04-25-2011 07:48 AM
nitroduck
06-13-2010 08:36 PM
ta8218
09-20-2007 08:08 PM
IDL
04-26-2007 10:56 PM
Quick Reply: Noise after rear tire change
