No fuel? Maybe.
Old Jul 29, 2012 | 03:15 PM
mj.heil's Avatar
Default No fuel? Maybe.
i did an engine rebuild on my 95 F3, i have 120 pounds of compression (should go up once valves seat properly). I have spark. But it wont start. wont even fire. i sprayed ether down the throats and nothing at all. but when i put gas down the throats you could tell it wanted to fire, there was less strain on the starter like it was being helped. I checked the fuel pump and it works fine, any help please?
Old Jul 29, 2012 | 05:32 PM
Nick Long's Avatar
simular to what happened to me
make sure the carbs are sitting tight down on the engine with no air leaks on the inlet rubbers
make sure fuel lines are not getting squashed
fill the fuel lines (after pump, before carbs) with fuel and then connect pump on
make sure the leads are on correctly left coil goes to 2 and 3 right coil goes to 1 and 4 (i had left going to 1 and 2 and right going to 3 and 4 DOH!)
also make sure the fuel cut out relay wires are not corroded at all and that the relay is working
and also that the earth is good on the regulator rectifier thing
My bike is now running after doing those few things however mine is now starting to drop down onto 3 cylinders as im riding which is driving me nuts!
Old Jul 30, 2012 | 09:32 AM
mj.heil's Avatar
alright, my leads are on correctly. i realized i had them on wrong a couple weeks ago. Fixed them, didnt help.
What is the fuel cut off relay and where would i find it?
"and also that the earth is good on the regulator rectifier thing" and what does that mean?
But i was also spraying straight ether down the throats and it didnt fire on that. So even if i wasnt getting gas it shouldve fired on the ether. thats what doesnt make sense.
Old Jul 30, 2012 | 12:38 PM
Nick Long's Avatar
the fuel cut out relay is situated by the regulator rectifier on by the rear light mounted on the side of the frame the relay has a little white 3 pin plug going to it
it controls the coil as well as the power to the fuel pump its a right pain!
you can test the earth on the regulator with a multi meter its the green wire and it earths out on the frame right next to it you cant miss it once you have the rear seat and fairing off
Kopi Ko
Sep 6, 2024 12:02 AM
Mulkxican88
Nov 14, 2013 05:23 PM
Bryantsito
Mar 25, 2012 02:40 PM
Rockshoxtora
Aug 12, 2010 03:58 PM
