lowering a F3
Old Apr 9, 2006 | 03:30 PM
mattleo's Avatar
Default lowering a F3
is this possible and how dificuilt is this. does the bike have any adjustments like other bikes i am only looking for a half or full inch . thanks guys. !
-matt leo
Old Apr 9, 2006 | 07:26 PM
rafo!'s Avatar
Default RE: lowering a F3
need a dog bone, thats located under the rear shock...its some what a pain in the ***. JUst make sure u take your time and have jacks and stands supporting your bike u can hurt yourself or damage your bike....i locacted a adjustable dogbone that lowers the bike from an 1/8 to 3inches instead of the cheesy 1 to 3 inch only.............good luck.....
Old Apr 14, 2006 | 04:14 AM
cbrclan's Avatar
I have the same problem, question/concern. But when I called the local motorcycle dealer they said they don't recommend lowering since it will ruin the way the suspension's ride and suggested that I either shave the seat or turn the suspension down to the lowest setting. I also called up a motorcycle upholstery shop and they said 200 buckaroos!! This is to take out the original foam and put it a thin foam in since the chair doesn't have much to cut out originally.
200 is way too much in my opinion to be shaving off the seat.
Anyways, does anyone know a lower bike handles compared to factory?
Old Apr 14, 2006 | 05:05 AM
DThompson's Avatar
Id think you would have a harder time shifting from left to right if you were draggin your knee in corners, because with the bike setting higher, it gives more of a top heavy feel to it and its easier to role from one side to the other because of the weight being up higher.
Old Apr 15, 2006 | 12:28 AM
Downforce137's Avatar
Lowering the rear with a link, severely changes the spring rate in the rear, making the ride much harsher.. You lose some handling, but it's mostly due to ground clearance issues when leaned over. Mine was lowered an inch when I got it, and it was ok for awhile, but once I put a stock dogbone and slid the forks back down, it rode and cornered much better.. didn't have to take it easy in turns, since my footpegs werent dragging and sparking.. I'd say 200 is a bit much, try some other shops, I know a dood with a Katana, that had the foam removed and they installed gel pads, and recovered for 100 bux.. Keep shopping around, but I wouldn't recommend the lowering link idea..
Old Apr 18, 2006 | 08:18 PM
L4S's Avatar
L4S
you can shave the foam down on the seat your self,
all you have to do is taker the seat off, then remove the cover it is held in by heave dutie staples
take a electric knife and shave the seat to wear you want it then re-staple the seat cover back on, it should give you the 1/2 inch to 1 inch you are looking for
as far a lowering the bike, it handles like **** and bottoms out when you come out of a wheele. i have also torn up my shoe pretty good trying to corner the bike due to the fact your pegs hit alot soon then if at stock hit
Old Apr 19, 2006 | 02:14 PM
cbrclan's Avatar
Good tip! some guy who's done this already is willing to help me shave my seat for a pack of beer.
subyman1440
May 7, 2012 06:26 AM
Hustlin Hussy F4I
May 4, 2012 10:39 AM
jtboyd91
Jul 23, 2010 08:24 PM
Getz2003
Jan 17, 2009 01:42 PM
BADassCBR
Jan 19, 2007 06:41 AM
