Lost power while on the freeway!
Old 12-18-2009, 02:17 AM
murdocity's Avatar
Yea they replaced it with the oem r/r. which one do you recommend kuroshio
  #32
Old 12-18-2009, 05:08 AM
Kuroshio's Avatar
Guys have used one from a Kawasaki, I believe, to replace theirs. I don't know which one tho.
Personally when mine goes, I wouldn't go the Ebay route. This is one of those applications I wouldn't trust to a part with a sketchy history.
I heard good things about these guys for an aftermarket replacement
  #33
Old 12-18-2009, 05:16 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
they make some with fans the blow on the sinks,
though i don't know if they work well or not
  #34
Old 12-18-2009, 02:46 PM
chuckbear's Avatar
Seems a little overkill to me.
Having had a bad R/R on the bike when I got mine I speak a little from experience. I got a used stocker for $15 from a nice member here and have been rocking it for about a year now with no problem. Had it not been for that, I would have gone aftermarket.
I can see that advantage of a heat sink on the aftermarket ones but a fan just seems like more than you really need. Seems like the heat sink is plenty of extra heat dissipation.
  #35
Old 12-18-2009, 03:27 PM
normally id agree,
but with chinese plastics and how easy they melt/bend/warp
and how hot that r/r gets,
i think it can be a good solution at least for bikes like mine
  #36
Old 12-29-2009, 10:39 AM
murdocity's Avatar
Where is the Jumper Cable for when I want to jump the Fuel Cut off Relay? Is it a separate cable or is it attached? I checked and I got Three Wires on the connector.
  #37
Old 12-29-2009, 10:45 AM
Kuroshio's Avatar
There is no "cable". To jumper it you take a piece of wire and bridge 2 wires on the connector. I don't remember which wires since its been a while since I did it. If nobody has chimed in by the time I get home, I'll post it up.
  #38
Old 12-29-2009, 10:55 AM
chuckbear's Avatar
normally id agree,
WTF... when does your R/R get that hot? You might want to check if your stator's working too hard or something. Even my stocker with no heat sink doesn't even get close to that hot..
  #39
Old 12-29-2009, 11:27 AM
murdocity's Avatar
kuro... if you could post it up that would be great... does it matter what kind of wire it is?
  #40
Old 12-29-2009, 11:28 AM
murdocity's Avatar
If I "jump" it, how long can I have it like that, or is it just to check if the relay is bad?
Quick Reply: Lost power while on the freeway!
