License plate plastic delete?
Most people use the kits that are available. You can trim the plastic and leave enough material to mount some small pedestal signals by drilling holes. If you trim just the material below the side panels, there is enough material to mount the license plate up and in the existing gap. You have to cut a hole in the underside of the rear light and glue some clear plastic over the opening to light your plate. You will also need to trim the upper edge of the license plate to fit in the opening. If you only trim what you need, no one will notice. (23 yrs so far)
6doubleohf3
How-To: Mechanical
May 1, 2009 01:59 AM
