LED turnsignals... Can we flushmount?
ARRGH ... a bunch of manufacturers SAY their LED flushmounts fit our F3 as well as F4's but if they claim that - they are WRONG. Seems that the hole in our fairings for the turn signals are bigger than the newer F4 models.
Who knows what flushmounts to buy??? I've seen some kewl pictures in the our picture thread so it's got to be possible! If not flushmounts, how about other kewl/affordable LED short stem signals?
Turns out the hole in the F3 is 32.5mm at the widest part of the oval, and 54mm long - the products for the F4/F4i are only 50mm long. Looking it up on RonAyers- our turn signal OEM part 33650-MAS-671 is only compatible with the CBR900RR and CBR600SE (93-99 & 98 respectively)
Originally Posted by GotCBR;
use any flushmount LED signals w/ backing plates
Yeah I ordered mine assuming they'd fit. If you're planning on painting, you can fill your original signal holes with fiberglass, bondo, etc. Just fill the holes and when it's all sanded down just drill a single hole big enough for the wires of the signal to fit through. They usually come with that sticky pad, so all you do is slide the wires through and stick it on. Here's a picture.
I actually placed mine a bit higher. Looked better to me.
Zach- looks gr8! Where did you get those fairings?
Yeah I'd like to know if somebody found flushmounts that fit over holes without having to mod the fairings. Anybody?
There's a number of "adapter plates" available also - but from what I can see they look like crap.
ok... so the quality's not great (taken with my phone) but you get the idea... the flushmounts cover the hole no problem (see second pic) but as they have a flat back, and the fairings are curved, it's not a great fit.
These are designed to be mounted with the supplied double sided tape, but I'm thinking a few basic modifications to the lights (and a couple of small holes in the fairings) and these will screw on nicely with some of the backing plates removed.
Looking good dark...
Kewl so which ones did you buy?? Looks like a great improvement for <$10
Still can't figure it out 'cause so few of them are 5.4cm long. The pictures you posted look a bit like: Flush Mount Sportsbikes Turn Signals for Ninja ZX6 ZX7 ZX9 ZX10 ZX12 ZX 6R 12R | eBay
But only too short 'cause they're only 4.8cm long. These ones are 'for cbr600F3' but also too short: LED Turn Signals For Honda CBR CB 600 F3 F4 F4i 900 929 954 1000 RR VFR | eBay
BTW where do u live down under? My best bud and frequent pillion passenger just moved to Sydney
Still can't figure it out 'cause so few of them are 5.4cm long. The pictures you posted look a bit like: Flush Mount Sportsbikes Turn Signals for Ninja ZX6 ZX7 ZX9 ZX10 ZX12 ZX 6R 12R | eBayBut only too short 'cause they're only 4.8cm long. These ones are 'for cbr600F3' but also too short: LED Turn Signals For Honda CBR CB 600 F3 F4 F4i 900 929 954 1000 RR VFR | eBay
I'm in Melbourne (well, the outer suburbs of Melbourne at least)
