K&N & Carbs
RE: K&N & Carbs
when you use a K&N filter, it will allow more air into the carbs. You might not notice the difference but you will be running lean. regardless. If you decide to put an exhuast on, you'll probably have to rejet the carbs to allow more gas in to match the air. A slip on w/ K&N will probably evan require a jet kit.
Just my .02
Just my .02
