Jetting sizes.
Old Sep 24, 2021 | 11:47 AM
Denali's Avatar
Default Jetting sizes.
Okay. So I recently gave in and dropped my bike off at an awesome local shop for diagnoses. (80 metrics) Burnsville NC
Im trying to figure out jet sizes for the bike
slip On with minor baffling and a k&n air filter.
does anyone have a setup similar to mine? Or any experience and guidance with what jets sizes to get
thank you much! -Denali
Old Sep 25, 2021 | 04:11 PM
Unless you put a header on it, I don't think I'd change any.
Old Sep 25, 2021 | 06:44 PM
Denali's Avatar
idodirt! Good to hear from you again!!! It’s sputtering at low rpm’s. The high end is phenomenal. It’s also running SUPER RICH
Old Sep 25, 2021 | 08:36 PM
Seems strange that it would be rich. A K&N would theoretically provide more airflow right? So leaner. Slip-on, again more airflow (not really but many think so), so again leaner. Factory jets still seem to me to be the right way to go. Now if you're at high altitude, then smaller jets might be in order. Are you at high altitude, like Denver or something similar?
Old Sep 26, 2021 | 09:31 AM
Denali's Avatar
theoretically, hm it seems curious. I wonder if the jets aren’t stock.
Old Sep 26, 2021 | 09:55 AM
If you're not the original owner of the bike, then it's really hard to know what might have happened in the bikes "youth". 135's on 1 and 4, 138's on 2 and 3 is stock for 48 state models.
Old Sep 26, 2021 | 03:01 PM
Denali's Avatar
thanks idodirt. I guess my next question is. If f3 carbs and f2 carbs are the same if not identical. I know there are a lot of shared pets between the models
Old Sep 26, 2021 | 10:29 PM
They are definitely not identical. Honda learned a lot and there were a number of refinements to the F3's carburetors.
Old Nov 7, 2021 | 03:13 PM
rokitrick's Avatar
Default Carb diff
F2 carbs are 34mm where the F3 are 36mm. The F2 airbox takes air in under the tank. The F3 uses ram air, so there's extra hoses to maintain pressure in the float bowls
Old Nov 7, 2021 | 03:24 PM
rokitrick's Avatar
Default Rich rich
I think of extra "air flow" more of as extra "mixture flow". Because of the extra velocity, its drawing in more mixture and therefore more fuel. I actually jet down with a free flowing filter and/or exhaust.
ohiosledneck
Oct 4, 2013 10:44 AM
KCITYRIDER
Jul 24, 2008 09:53 AM
PatsCBR
Dec 15, 2006 02:05 PM
DempsRS
Jul 12, 2006 02:05 AM
ericmxzx440
Nov 2, 2005 07:43 PM
