jet n
Old Aug 18, 2008 | 08:06 PM
cowboy from hell's Avatar
Default jet n
question: on an f3 the mains in the center are different from the outside ones 135 for no. 1 and 4 / 138 for number 2 and 3 so my question is why? why does the outside run leaner than the inside is due to the flow charistics of the ram air? got an f2 here with pressurized box wondering if i should look into this matter my jets are the same all the way across but iam always looking for ways to get alittle more juice.
question 2: f3s use #40 slow jets now ive heard these kickass in an f2 so are they interchangeable? i.e. same thread/dimensions?
Old Aug 20, 2008 | 11:12 PM
kwong2001's Avatar
Default RE: jet n
I think it has something to do with the velocity stacks being different lengths.
Old Aug 21, 2008 | 08:26 AM
redzintimidator's Avatar
Default RE: jet n
arent the stacks the same length?? At least mine are[&:]... Are your carbs sync'ed up correctly?..doesnt sound like it
Old Aug 21, 2008 | 10:18 AM
Default RE: jet n
ORIGINAL: redzintimidator
anyway came to find out its just the way the f3 carbs are disgned the inner two cylinders run a bit hotter than the otter two. still wonder if the pilot jets will work will find out soon enough ordered 1 from bike bandit for 8$ just to see if itll work.
Old Aug 21, 2008 | 08:44 PM
kwong2001's Avatar
Default RE: jet n
Stock is different lengths
Old Aug 22, 2008 | 07:17 AM
kjohnson's Avatar
Default RE: jet n
ORIGINAL: cowboy from hell
The inner cylinders run hotter than the outer ones because they get less air than the outer ones.The extra fuel cools the inner cylinders .
Yes,the 40 pilot jets rock in the F2s
