irractic rpms only when warm help.???
Old Aug 31, 2009 | 04:06 PM
1iwilly's Avatar
Question irractic rpms only when warm help.???
hello to all
i have 97 cbr 600 f3 that i bought 1 month ago the guy sold the muffler he had on it and gave me a muffler that came off a newer bike it is stock muffler but had a o2 sensor hole that i plug off and i gutted the inside because it was also a catalityst converter unit.any way here is my problem the bike when it is cold would idle kind of ok then once it warms up meaning if stuck in traffic alot and temp goes from the middle of gauge to 3/4 the idle start to go hi then back to normal or when it does goes back down bike would shut off unless i keep rev it so not to shut off
and at that time the fumes coming out of the exhaust smell rich it runs good and strong until you have to stop for traffic lights it is not over heating at all the minute i take off the temp goes way down i don't know if bike was jetted when the other owner had as he didn't metion it to me
so being that i'm running a oem muffler should i be running stock jets??.
my main issue is the idle going hi after engine warms up any one else experience this promblem and what was the fix??
Old Sep 1, 2009 | 10:39 AM
johnnyx's Avatar
A.) Is your radiator fan working?
B.) When's the last time you changed your air filter?
Old Sep 1, 2009 | 01:24 PM
1iwilly's Avatar
Exclamation
yes all the basics been check out fan comes on at the right temp
i also check to make sure there were no air pockets in the cooling system
Old Sep 1, 2009 | 01:46 PM
johnnyx's Avatar
Sounds like a carburetor issue. . .stuck float valves or some ilk. The a/f mixture is fluctuating. When's the last time you gave them a going over?
Old Sep 1, 2009 | 04:48 PM
1iwilly's Avatar
Exclamation
i just got this bike a month ago so this is new to me
Old Sep 2, 2009 | 10:19 AM
johnnyx's Avatar
Ah, cool. Follow Dissevered's how-to on carb cleaning. He sleeps with the things under his pillow.
https://cbrforum.com/forum/f2-tech-93/carburetor-cleaning-tuning-101-a-96888/
ParlousKis
Aug 27, 2011 09:47 PM
tomttt
Feb 21, 2010 07:23 PM
philthethrillohio
Feb 11, 2010 03:00 PM
darkyuy
Jun 10, 2009 11:49 PM
cyber00677
Apr 9, 2008 04:51 PM
