Inside look at what the CCT is doing
Old Sep 28, 2009 | 09:55 PM
marc0011's Avatar
Default Inside look at what the CCT is doing
I've been seeing a lot of CCT questions on here lately and I just happened to be in that area of my bike this last weekend. While fixing an oil leak, I took a couple of pics so that others can see exactly what the CCT is doing. It is pushing on a cam chain guide which in turn puts tension in the cam chain. Of course, there is the factory set it and forget it (until the marble is set loose when cold) or the manual tensioner. Both tensioners perform the same function though.
Attached Thumbnails Inside look at what the CCT is doing-cct_close-1.jpg   Inside look at what the CCT is doing-cct_close-2.jpg   Inside look at what the CCT is doing-cct_close-3.jpg   Inside look at what the CCT is doing-cct_distant.jpg
Old Sep 29, 2009 | 07:11 AM
Northernfirepower's Avatar
Awesome post marc! Should really really help answer a lot of questions with just one look
Old Sep 29, 2009 | 06:53 PM
CBR600F3ROX's Avatar
Nice half put-together bike!
Old Sep 29, 2009 | 08:19 PM
P_Glasovatz's Avatar
Good post! Definitely helps to visualize how the CCT is interacting with cam chain, especially when manually adjusting it.
Old Sep 29, 2009 | 09:37 PM
Fastridingman's Avatar
Thanks for taking the time.
Old Sep 29, 2009 | 09:50 PM
Another thing that you can see in the photo's is that the crankshaft rotates clockwise as viewed from this end. With that in mind, the crankshaft is always pulling on the right side of the chain and providing slack on the left side. That's what the tensioner does, it takes up all the slack and keeps it moving smoothly up to the intake camshaft. Good photos. Nice job.
billetproof97
Jan 16, 2011 11:29 PM
skoal
Feb 22, 2007 11:06 PM
Triangle
May 24, 2006 08:50 AM
desimojo
Mar 30, 2006 10:20 AM
trixtrem
Oct 6, 2005 09:49 PM
