idle screw came off - help!
Old Jul 9, 2007 | 11:48 PM
joelacer's Avatar
Default idle screw came off - help!
Hi everyone,
So my bike kept stalling out recently and I discovered that the idle screw came detached from wherever it connects to, somewhere near the throttle/carbs im guessing. I took off the the fairings, the gas tank, and part of the air box assembly. But I can't really tell where the other end of the idle cable connects to. I think I may have found it, but it looks like its impossible to reconnect it without removing the entire carb assembly, which looks like a major pain. so do any of you know how to re-attach the idle screwwithout taking apart the entire bike? any help would be appreciated.
Old Jul 10, 2007 | 05:38 AM
pointman's Avatar
Default RE: idle screw came off - help!
remove the fairings adn tank its between the two center carbs you have to fit your hands in there just enough to guide it. use the **** itself to turn it in . its a tight fit but it can be done .you have to slip your hand in from the left side thats how i did mine . gl
Ls1Mx5
May 18, 2015 07:32 PM
superlund
May 7, 2010 09:51 PM
crhallcbr
Sep 21, 2008 08:12 PM
TennesseeCBRF2
Apr 26, 2008 03:02 PM
rockdicasbah
Sep 15, 2007 07:53 PM
