Where does my idle adjustment screw into?
Old Sep 11, 2007 | 06:38 PM
rockdicasbah's Avatar
Default Where does my idle adjustment screw into?
the idle adjust got disconnected, where does it connect to? I cant seem to find the hole
thanks for your help!
Old Sep 11, 2007 | 08:27 PM
felk27t's Avatar
Default RE: Where does my idle adjustment screw into?
disconnected where???? from the carbs or the clip on the frame???
Old Sep 11, 2007 | 11:42 PM
it got unscrwed from the carbs
Old Sep 14, 2007 | 07:52 PM
Acara1796's Avatar
The adjustment is located between carbs two and three near the throttle cable hookups. The easiest way to get to it is to remove the airbox.
Old Sep 15, 2007 | 02:02 AM
nieuwsma's Avatar
Recently posted this when someone asked me where to put it into..
Hey I can help you brotha! I too was on your end, and came to the forums and did not recieve much help, because this suprisngly dosnt hapeen much. But since it happend to me i can help u! When i scrwed it back in i took the tank, airbox, and carbs out out of frustration just to find out where that peice of crap goes. But all you need to do is take off the side and back fairings and you will be able to do this.!
This screws into a little nipple hanging down between the 2nd and 3rd carb. If you are sitting on the bike the carbs go from left to right as 1234.
The nipple is silver, and hangs down on the top of the 3rd pointing down. Behind this nipple you will see a lever and a few pullys. Just screw it up right into that nipple. Its easier with 2 pairs of hands, but when i did it i had my right hand down holding it in place, and the left hand screwing the **** and it screwed right up there!
Hope i helped!
Old Sep 15, 2007 | 07:01 PM
Acara1796's Avatar
I needed to take the airbox off because I have a California model with all the emission crap, which just happens to very much in the way. Yeap, the plastic was all off too.
Can you guess...It happened to me as well. Happened during restoration, trying to get it started after sitting for over eight years.
Old Sep 15, 2007 | 07:42 PM
nieuwsma's Avatar
yeah it happend to me to the second day i had my bike! i woke up early one morning to go and ride, and it wouldnt start, i was sooo confused. so i checked everything, and randomly i was messing with that and i realized it wasnt screwed in. It sucked to do all that cause of my fat hands.. but o well
Old Sep 15, 2007 | 07:53 PM
Acara1796's Avatar
Uuugg, nothing worse then getting ready to go ride and the the thing won't start. It can be quite depressing.
Sean1000f
Jul 2, 2013 01:44 PM
Mr. Phil
Aug 30, 2012 03:38 PM
compster
Sep 17, 2010 07:08 AM
98cbr600se
Oct 29, 2008 06:29 PM
raredogg
Apr 28, 2006 05:43 PM
