Idle???
RE: Idle???
Seafoam is a god send! I just wish we could get it up here north of the border...I used up the last of what I brought back from my last trip south. Other thing it could be is leaky carb intakes. Spray some carb cleaner around the intake boots and see if it changes the idle at all...if it drops you have a leak.
RE: Idle???
It is also struggling to turn over the engine so I suspected the spark plugs needed to be changed. I didn't know if one of the spark plugs might not be firing good and it was causing the inconsistancy in the idle. I will try the seafoam and carb cleaner and keep you posted. Thanks!
