I replaced the air filter and now my Bike does not turn on!!!
I replaced the air filter and cleaned hoses around and prior to that the bike had been running ok..now it does not start. I turned it of after I noticed like water coming out of ignition pulse generator rotor cover cap..right side of engine..weird??..next day I removed the pulse generator rotor cover cap..and it was fine...also noticed a bit of water coming out of my two brother exhaust, not by the end just by the union with me exaust system.....Can please somebody guide me here I am lost..now I drained the battery....i gotta get it charged!!..appreciate any comments!!!..Ivan
Most likely you've got something either hooked up wrong or left disconnected. If it was working before, then it's something you did while you were working on it. Go back over it and verify each connection. There is a hose diagram on the air cleaner cover if I recall correctly. That should help you verify things. As for the water in the exhaust, condensation is a normal port of internal combustion. I wouldn't give it too much thought unless it persists after the bike is running and warms up.
try bumping the bike
most people forget that petrol evaporates in your carb pipes so when they are pulled off the carb becomes what i call 'dry' give it a bump start in 2nd is easyest as 3rd trys to take off. give the throttle a couple of twists like one or two and then try it as for the water if you in the uk its winter mate so just be condensation.
mcmahan87
06-05-2013 05:13 PM
Survivalism
07-20-2011 01:33 PM
REPLACED ENGINE due to cracked gear case, and now the bike won't start :[ HEEEELLLLLPPP PLEEEASEEE!!
hesner
How-To: Mechanical
02-27-2008 01:22 AM
