I like my F3 but not when i cant ride it! help inside
ok gang. bike is a 96 F3. i bought a brand new battery, brand new R/R for it and a new rectifier plug since the last one got fried along with the R/R, i threw a voltage meter on it and its holding at 14.X volts and nothing comes on, no lights, no dash lights, etc. only thing thats working is my alarm. insight would be great. im frustrated with it. maybe diagram of the wiring to the R/R would help. or is it possible i need a new stator?
Brandon
Brandon
Brandon
Brandon
The other possibility is a bad ignition switch, but that is less likely than the main fuse. Download the manual from StephyGees site.
update
update: I took IDoDirt's advice and looked at the 30A fuse and sure enough it was popped. so i got a pack of like 5 30A fuses at walmart for like 2 bucks. put one in and she turned on, and it took a bit to start it up because it sat for a good while. but i got her started and rode her around the block and took her on the highway a little bit and she runs damn well. i need to replace the chain and put my new tire i got sitting here on the bike.(anyone know a good way to pull an old tire off yourself? im sure there are tools but has anyone pulled a tire without a tire puller? i got some new progrip gel grips i need to put on it too and some bar ends. I just want to thank IDoDirt again for the help with out his info i wouldnt have gotten it started.
Brandon
Brandon
