How serious is this?
Old Oct 16, 2007 | 10:51 PM
notny41's Avatar
Default How serious is this?
It is on the left side top support brace (frame) / engine mount. Bike seems to ride just fine. Fixable? There's a hole below it that does not go all the way through that I was thinking of making a bracket for to bolt to the frame.
http://home.comcast.net/~novotny.family/cracked.JPG
Not sure why the pic wasn't working...
Old Oct 16, 2007 | 11:37 PM
tomvoy's Avatar
Default RE: How serious is this?
[sm=redx.gif]
Old Oct 17, 2007 | 12:16 AM
notny41's Avatar
gonna have to click on the link for some reason...
Sorry about that.
Old Oct 17, 2007 | 12:22 AM
Scrufdog's Avatar
hmmmm
well, i dont forsee the motor falling out very soon....but the extra stress it may be putting on the other engine mounts might not be good. I'd ride it to a machine shop and have someone look at it and see if they can fix it.
Old Oct 17, 2007 | 09:25 AM
Northernfirepower's Avatar
Damn, wonder how that even happened...anyway, do you still have the original piece that came from there? Only reason I ask is because you could JB weld it back on and call her good. That's the path I'd take...try and fab a replacement that could cover that area for support again. Otherwise I don't think that I'd loose sleep riding it like that.
Old Oct 17, 2007 | 10:04 AM
notny41's Avatar
Yeah, not sure how it happened - it was like that when I got it. I've put about 5 miles on it but it doesn't seem to be getting any worse. No, unfortunately I don't have the chunk.
Old Oct 17, 2007 | 02:23 PM
marc0011's Avatar
Man... I've never seen that! Guess you have three options, fix it by to cutting off of the end (where the bolt passes through) and weld on another tube with same dimensions. I think this would be incredibly difficult because finding a tube of aluminum that'll fit and welding on the new aluminum piece... never donealuminum myself but hear it is really hard. You could replace the upper half of the block is another option but that would be a lot of work and money. Lastly and most likely, you could leave it as is. Man... you're in a rock anda hard spot with this. Wish I had some better words of advice for ya.
Old Oct 18, 2007 | 02:04 AM
Sand.Man's Avatar
I'm a welder, welding aluminum is not hard... It's just about surface prep.
Welding CAST aluminum on the other hand...
I'd say it is repairable, I wouldn't leave it like that for long!
Old Oct 18, 2007 | 10:23 PM
redzintimidator's Avatar
get some chunk of aluminum to replicate the chunk that broke off..n go to town on welding it...aluminum melts a lot so try n have a pro do it...
