How do I tel if my carbs have been jetted?
If it's a Dynojet stage 1 kit, it'll work. I just checked the instructions for the stage 1 kit and that's the recommended setup for an aftermarket exhaust / high flow baflle slip on and a k & n filter. if that's not your setup, you'll be running very rich.
Another way to tell is something IDoDirt mentioned: do the slides in the carbs have drill holes in them? Dynojet is the only kit I know of that asks the person to drill the slides
Does anyone know what size the drill is that's included in the Stage 1 kit ?
Then it's a Dynojet needle in there. Given the sizes you stated, it's prolly a full Dynojet stage 1 kit. Might as well assume that whoever did the jetting also drilled the slides. Since the stage 1 kit comes with the drill bit, there's no reason not to do it.
That setup is for a modded bike, with aftermarket exhaust and air filter. Your bike should be fine with those settings. Won't be optimal cause that really requires some time spent on a dyno with a mechanic that knows what he's doing. So I'd not expect a massive power increase. But it'll be close and won't be the cause of any performance problems
All needles are tapered. That's the point of them sliding out as the speed of the engine increases. Now, how much of a taper and how rapidly they change may vary between manufacturers, but they're all tapered. Factory needles don't have clips. If you have clips, then they're not factory.
Not from my carbs. If I get into them tomorrow I'll take a pic to compare. But you'll notice the stock needle pictured goes straight down to a point. While the DJ needles have a slight flair to them.
