Goo Gone
Old Jan 15, 2010 | 10:27 AM
roys654's Avatar
Default Goo Gone
Was not sure where to post this but does anyone have a good way of getting rid of decal glue? I have had to remove all decals from bike and need to get the very old well stuck sticky stuff off the fairings. Goo Gone is not working very well. Any ideas would be greatly appreciated.
Old Jan 15, 2010 | 12:09 PM
murdocity's Avatar
I used the Stoner Tarminator when I went to take off the decals to prime my fairings. Make sure you do it somewhere where you have ventilation, it has a strong smell, but that stuff works. Goo Gone is a pain in the ***, with the Tarminator all you do is spray and let it sit for a couple of minutes then rinse it off and wipe with a towel.
Old Jan 15, 2010 | 05:56 PM
willduce's Avatar
Ive got some KRUD CUTTER "super bad *** citrus removes any thing ever made in the universe" stuff. i bought it at menards for 8 bucks. removes anything but is plastic safe. here it is http://doitbest.com/Main.aspx?PageID...paign=DATAFEED
Old Jan 15, 2010 | 06:04 PM
pacemaker's Avatar
Eucalyptus oil
Old Jan 16, 2010 | 01:06 PM
budgie600's Avatar
best stuff money can buy is lighter fluid, removes any glue from anything and leaves no trace,
Old Jan 16, 2010 | 02:10 PM
K7inne09's Avatar
If you can get your hands on it, use some stuff called ProSol...Lacquer Thinner works also on vehicles and such, dont know how it will respond to plastic)....I work at a sign shop and I have used both with no problem almost daily. As someone else said, do it in a well ventilated area the sh*t will have you spinning...
Old Jan 18, 2010 | 08:20 AM
Krux's Avatar
Krud Kutter is decent. Rustoleum just came out with a decal remover that is suppose to be safe for anything. I would suggest that to get.
Old Jan 19, 2010 | 12:27 PM
roys654's Avatar
Thanks everyone
Old Jan 19, 2010 | 01:07 PM
Ruthless's Avatar
If that stuff doesn't work. Try sandpaper.
