Goo Gone
Was not sure where to post this but does anyone have a good way of getting rid of decal glue? I have had to remove all decals from bike and need to get the very old well stuck sticky stuff off the fairings. Goo Gone is not working very well. Any ideas would be greatly appreciated.
1 Attachment(s)
I used the Stoner Tarminator when I went to take off the decals to prime my fairings. Make sure you do it somewhere where you have ventilation, it has a strong smell, but that stuff works. Goo Gone is a pain in the ass, with the Tarminator all you do is spray and let it sit for a couple of minutes then rinse it off and wipe with a towel.
Ive got some KRUD CUTTER "super bad ass citrus removes any thing ever made in the universe" stuff. i bought it at menards for 8 bucks. removes anything but is plastic safe. here it is http://doitbest.com/Main.aspx?PageID...paign=DATAFEED
Eucalyptus oil
best stuff money can buy is lighter fluid, removes any glue from anything and leaves no trace,
If you can get your hands on it, use some stuff called ProSol...Lacquer Thinner works also on vehicles and such, dont know how it will respond to plastic)....I work at a sign shop and I have used both with no problem almost daily. As someone else said, do it in a well ventilated area the sh*t will have you spinning...
Krud Kutter is decent. Rustoleum just came out with a decal remover that is suppose to be safe for anything. I would suggest that to get.
Thanks everyone
If that stuff doesn't work. Try sandpaper.
