The hose is extra from what my other bike had, CA Type? HELP
Old Sep 8, 2012 | 08:46 PM
dyracuse's Avatar
Default The hose is extra from what my other bike had, CA Type? HELP
I looked at the cylinder heads I had lying around the garage and neither of them have the third hose in between the two coolant hoses that normally come off the head. Mine has an extra one right next to the left of cylinder 3's intake. I am wondering if this is a California Type engine and if I should block that line off or what I am supposed to do with it. The bike started right up way quicker than with the old engine, however it shoots water out of that line, which clearly has no place to go on my 49 state bike, not sure how a Cali engine got over here anyways. If you could help I would really appreciate it.
Old Sep 8, 2012 | 08:59 PM
74demon's Avatar
Plug it and put coolant in it. If there is a place where it goes, it will be obvious. If it runs and holds pressure, its extra.
Old Sep 8, 2012 | 09:57 PM
dyracuse's Avatar
It will be obvious how? Like it will overheat or something, like how would I know once I plugged that line and ran it if it was good or not? Not sure how I can see if I have pressure or not, I know how to turn a wrench well, but my troubleshooting skills are horrendous.
Old Sep 8, 2012 | 10:02 PM
74demon's Avatar
It will be obvious because water will be coming out all over the place. As it runs, it will build pressure. It can't get pressure with a hole in the system.
Old Sep 8, 2012 | 10:20 PM
dyracuse's Avatar
I plugged it before and no water was coming out anywhere. So there's no obvious place that the hose should go on my 49 state bike.
Old Sep 8, 2012 | 10:41 PM
74demon's Avatar
Then....its extra. Just plug it.
Old Sep 8, 2012 | 11:56 PM
dyracuse's Avatar
Ok, I just always worry when something is "extra", usually turns out not to be, but I think in this case it goes to a system this bike doesn't have.
NateDieselF4i
Jul 28, 2012 02:05 PM
james007torres24
Jan 2, 2007 09:35 PM
birde
Oct 23, 2006 04:31 AM
InTheMaking
Sep 19, 2006 06:18 PM
seabee
Feb 11, 2006 11:41 AM
