HELP stuck gas cap
Old Sep 28, 2010 | 10:22 AM
r3ap3r's Avatar
Default HELP stuck gas cap
ok i have 97 f3 and the key no longer opens the gas cap so i need help to open it to replace the cap
Old Sep 28, 2010 | 10:34 AM
kerosene's Avatar
it's just 3 screws that hold it, unscrew all of them that surround the gascap (8 I think) and it'll pop up.... why doesnt the key work?
Old Sep 28, 2010 | 05:48 PM
pacemaker's Avatar
My cap get stuck sometimes & I have to push down on the edge of the cap (as I turn the key) so it pops back up.
If it's the lock itself getting stuck, try a bit of graphite powder on the key (just don't get any in you're tank).
Old Sep 28, 2010 | 06:03 PM
r3ap3r's Avatar
Ever time I try and turn the I hear grinding or orunching sound and the key won't turn I bent almost bent the key
Old Sep 28, 2010 | 06:33 PM
r3ap3r's Avatar
Ill give that a try
Old Sep 28, 2010 | 09:42 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
if its locked, you cannot remove it even if the screws are taken out because its locked in.
the gascap must be unlocked in order to take it out.
Old Sep 30, 2010 | 09:32 AM
r3ap3r's Avatar
so i might have to drill it
Old Sep 30, 2010 | 11:30 AM
r3ap3r's Avatar
or after reading and much searching a few people have jammed a screw driver in there and opened tank
what do you guys think?
Old Sep 30, 2010 | 03:06 PM
DanishF3's Avatar
When i replaced my tankcap it was a little corroded in the lock, i just sprayed wd40 in the hole and worked it a little, made things go a lot more smoothly. If not, well, try hammering a screwdriver in the lock and open her up, just consider the fact that you'll have to change both the ignition and tank locks, if you dont want to ride around with two different keys, mixing em up and all... I think a set of used ignition and tanklocks cost me about 120$ at a scrapyard.
Old Sep 30, 2010 | 03:59 PM
SLORider18's Avatar
yeah, i would try the wd-40 and let it soak a little. busting that lock is gonna open a whole other can of worms.
