HELP stuck gas cap
the gascap must be unlocked in order to take it out.
When i replaced my tankcap it was a little corroded in the lock, i just sprayed wd40 in the hole and worked it a little, made things go a lot more smoothly. If not, well, try hammering a screwdriver in the lock and open her up, just consider the fact that you'll have to change both the ignition and tank locks, if you dont want to ride around with two different keys, mixing em up and all... I think a set of used ignition and tanklocks cost me about 120$ at a scrapyard.
