Headlight Prob
Old Mar 5, 2009 | 04:33 PM
89cane's Avatar
Default Headlight Prob
ok so i went to start my bike yester day and the headlight didnt turn on todey i have checked the fuse checked the light checked the left handle bar switch
I am at a loss for what to do or where to look and as my bike is the only form of transportation i have i need this fixed any ideas would be much apprecaited.
Old Mar 5, 2009 | 04:52 PM
rbs75's Avatar
headlight relay? or dead battery
Old Mar 5, 2009 | 04:56 PM
89cane's Avatar
battery is good where is the headlight relay?
Old Mar 5, 2009 | 05:11 PM
rbs75's Avatar
i'm not for sure as i have never had to replace one and the manual does not specify one as the headlight relay. gimme a minute and i will hook up a headlight to mine and disconnect the relays to see which one it is. i had thought that the flasher and headlight relay were the same for some reason.
Old Mar 5, 2009 | 05:15 PM
MrBomb's Avatar
check the starter switch, same thing happened to me and i found that a solder connection in the starter switch broke loose soldered it back together and that was it
Old Mar 5, 2009 | 05:29 PM
89cane's Avatar
its working again! I checked the solder connections as i had had that problem before on an older bike but that wasnt it. I played around with the connections in the right handle bar switch and got power again not sure what it was. i was checking for where i had power and where i didnt then i poked the headlight connection in there and the high beam light came on it had been not working either now it all works.
thanks to everyone for the help
Old Mar 5, 2009 | 05:39 PM
rbs75's Avatar
evidently, it doesn't have a headlight relay
Old Mar 5, 2009 | 07:18 PM
89cane's Avatar
thats cool thanks again for helping me out
Old Mar 5, 2009 | 10:17 PM
The starter switch is what provides power to the High/Low beam switch, then to the headlight. As a general rule, if only one of the lights is out, then either the bulb, or High/Low switch. If both are out, then the Starter Switch or fuse, or possibly wiring.
dec11
Mar 17, 2014 05:51 AM
brads94f2
F2 Tech
May 2, 2013 11:49 PM
MarkR
Nov 3, 2008 03:07 PM
tdiv135
Mar 25, 2008 04:24 AM
OCTOPUS
Jun 24, 2007 02:48 PM
