Headlight Prob
ok so i went to start my bike yester day and the headlight didnt turn on todey i have checked the fuse checked the light checked the left handle bar switch
I am at a loss for what to do or where to look and as my bike is the only form of transportation i have i need this fixed any ideas would be much apprecaited.
i'm not for sure as i have never had to replace one and the manual does not specify one as the headlight relay. gimme a minute and i will hook up a headlight to mine and disconnect the relays to see which one it is. i had thought that the flasher and headlight relay were the same for some reason.
its working again! I checked the solder connections as i had had that problem before on an older bike but that wasnt it. I played around with the connections in the right handle bar switch and got power again not sure what it was. i was checking for where i had power and where i didnt then i poked the headlight connection in there and the high beam light came on it had been not working either now it all works.
thanks to everyone for the help
