has anyone bought the electrosport rectifier?
Old Apr 4, 2013 | 05:18 PM
derekvercher's Avatar
Default has anyone bought the electrosport rectifier?
They claim its a heavy duty upgrade from oem. Just wanted to see if anyone has used it.
Old Apr 4, 2013 | 06:21 PM
Burnt Dragon's Avatar
I have one. Running fine for almost a year now. Has big cooling fins on it, so its supposed to dissipate heat better. Just thoroughly clean the plug-ins on your bikes harness before you plug it in. Corrosion increases ressistance.
Old Apr 4, 2013 | 06:35 PM
Cbrob2006's Avatar
New Member
I wouldn't recommend it I bought a stator and regulator from them. The regulator was bad out of the box. Had to order a Honda one next day. Then the stator went out in 200 miles. Do some research some people had good luck but a lot of people had bad luck! I recommend staying with Honda oem on the charging system!
Old Apr 4, 2013 | 07:49 PM
raylee's Avatar
If you're talking about Rick's, we've sold hundreds of them and in the time that I've been working I've seen about 1-2 stators being bad and maybe 5 or so of their regulator rectifiers being bad. I would also recommend the honda OEM, but I know that's a good chunk of change and I don't find the Rick's alternative to be that bad of one.
Old Apr 4, 2013 | 10:02 PM
cam and corona's Avatar
i run one. runs a little hot. melted some of my fairing near where the plug was burnt because of corroision or whatever on the plug. soon as i clean the plug should fix it. other then that no problems at all.
Old Apr 5, 2013 | 06:51 AM
Fobwareagle's Avatar
I have no experience with rick's but I replaced mine with one from a yamaha yzf600r over a year ago for $20 off ebay. Work's like a charm. It barely gets warm on a hot day. Just sayin there are other options.
Thaibiker85
Aug 28, 2009 07:01 PM
Fastridingman
Aug 24, 2009 04:33 PM
