Handlebars Vibrate?
Old Oct 15, 2007 | 02:57 PM
Thegreatone's Avatar
Default Handlebars Vibrate?
Handlebars vibrate at around 55 MPH. Just started happening. The front tire is almost at the wear marks. Could this be the problem or is it somthing else. Mabey a new front tire and balance would fix the problem?
Old Oct 15, 2007 | 03:34 PM
Sand.Man's Avatar
Default RE: Handlebars Vibrate?
New tire/balance and if the problem persists look into some heavier bar ends.
Old Oct 15, 2007 | 06:01 PM
notny41's Avatar
ORIGINAL: Hershey
+1 - hit it right on the head.
Old Oct 15, 2007 | 06:03 PM
Illushun's Avatar
^^ above posts are it. Sounds like the front tire has started to cup. or your wheel is out of balance as a result of the tire being worn.
Old Oct 16, 2007 | 09:19 AM
denlimack's Avatar
Will bar ends make that much of a difference? My F3 only has one on one side! Previous owner did a low speed drop (scraped the fairing and cracked it at one of the mounting points and I assume knocked off the bar end as it is no longer there!).
I just haven't gotten around to replacing it and didn't really notice a problem but as I have no prior experience with this bike maybe I am missing something in terms of the feel?
Dennis
Old Oct 16, 2007 | 09:57 AM
notny41's Avatar
These CBRs are pretty good for not having bar vibration - even with no ends I've found on my two. My FZR is a completely different story - there's a good reason they make those Yamaha bar ends so heavy. I'd bet it's your front tire if you didn't notice it before and now all of a sudden do.
Old Jan 6, 2008 | 11:36 PM
Asmittie84's Avatar
I just started a wobble around 55mph and main at decel. I have 1 bar end(Right side missing) but never noticed it until today.
I had the tire put on about a month ago.
So i'm wondering if it might be the bearings or something with teh tripple tree.
I'll call my motorcycle mechanic tommorow. He specializes in Race motors and Race Suspension(Especially Supermotard) so he'll probably know what it is but any advice is better than none.
Old Jan 7, 2008 | 09:37 AM
marc0011's Avatar
Amittie,
I might have a spare bar end. I'll have to go through and riffle through my crap... I don't exactly recall where I put it.
On the wobbles, is the tire going the right direction? I've read a lot on here where shops mount the tire in the wrong direction. If your steering head bearingswhere bad or loose,you would notice a forward and backwardslop motion in the whole front end when hitting the front breaks. Remember the days of bicycles and when the steering headnut would come loose, the handle bars slap around forwards and backwards when hitting the front brake. I would also check the bearings in the rimor maybe the balancing of the tire just didn't hold up.
Old Jan 7, 2008 | 02:20 PM
Asmittie84's Avatar
Actually part of the bar end is broke off in the handlebar. I'm going to have to buy a long bolt and use a slide hammer to get it out.
I forgot my motorcycle guy isn't open today but I'll bring it by to him tommorow and ask him.
I might end up going with new bars because I assume that if the bike crashed hard enough to break the bar end off it probably damaged the bars. But who knows I'll have it checked out.
Old Jan 7, 2008 | 02:37 PM
denlimack's Avatar
Mine is exactly the same way but seems to ride fine...admittedly I have only had her up to 195km/h so I don't really know how it would perform at high speed....
Dennis
Killerdimpler
Aug 5, 2013 07:18 PM
Michaud85
May 26, 2013 09:35 PM
Blarney
Mar 19, 2012 05:50 PM
lumberman
Aug 12, 2005 12:42 AM
