Gsxr r/r
Old May 9, 2009 | 04:28 PM
jpanside@gmail.com's Avatar
Default Gsxr r/r
I have been looking at all the GSXR R/R posts but I havent found an answer on how many connectors the R/R should have.
One connector or Two connectors?
I think the two connectors come with 6 wires and the one connectors come with 5.
does this even matter?
thanks bros
Old May 9, 2009 | 10:33 PM
It's not so much how many wires it has, but how many different colors of wires it has. Check this page.
http://www.offwidth.co.uk/bike/gener...lt_finding.pdf
Old May 10, 2009 | 10:26 AM
hmm so are you saying it is:
two black?
two red?
one white?
Old May 10, 2009 | 11:50 AM
No, I'm not saying that at all. What I'm saying is that the number of connectors is not important. Whether it has 1 connector or 2 doesn't matter. If you look at all the wires and put all the colors together, then according to the document, if there are 4 or less colors, then the regulator/rectifier is designed to work with a permanent magnet type of system. That's what our bikes use, a permanent magnet alternator. On the GSXR regulator I used it had 3 solid black wires, 1 black wire with a red stripe, and 1 black wire with a white stripe. That's a total of 3 different colors.
The 3 wires that are all the same color go to the alternator. The other 2 wires are the positive and negative wires that go to the battery for charging.
Old May 20, 2009 | 11:36 AM
stix818's Avatar
Which R/R did you use? I'm just going to order one and get r done!!!
Old May 20, 2009 | 09:36 PM
I just received this on from ebay today. Here is the auction # 140319181652
It's going on my wifes F3 this weekend.
CodyJ28
May 4, 2011 11:44 PM
RojerLockless
Apr 10, 2009 02:00 AM
blkout15
Feb 25, 2009 11:01 PM
pr0jktmayhem
Aug 26, 2008 03:41 PM
dirtyabes
May 9, 2008 04:20 PM
