Great way to ruin my day!!!
Thanks for everyones input.
I will take pictures as well to show what has happened, i am just afraid that when i take the covers off i will see something terrible and expensive.
Also if the chain did just pop off, should i still get a new chain set or just put the old chain back on and re-tension it? What kind of damage should i be looking for on the chain/sprockets to see if they should be replaced?
Thanks
Thanks
![Name: DSC02198.jpg
Size: 43.2 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62208d1501323174-great-way-ruin-my-day-dsc02198.jpg)
After you take it off, it's going to look something like this. As you can see there's quite a bit of sling and dirt and muck in there.
![Name: DSC02201.jpg
Size: 55.3 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62209d1501323174-great-way-ruin-my-day-dsc02201.jpg)
If you're going to take it apart, it's not a bad idea to do a little cleaning. There should be a "Steel" bracket behind the cover when you take it off. It's there as a protector to the engine since the engine case is aluminum. It only takes 1 bolt to get the front sprocket off and it comes off easily. You shouldn't need any special tool to remove the front sprocket. After cleaning it could look like this.
![Name: DSC02210.jpg
Size: 41.7 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62210d1501323174-great-way-ruin-my-day-dsc02210.jpg)
I can't even imagine what a chain or sprocket would have to look like in order to come off. There isn't much room for that to happen. If you take the rear wheel off (use a paddock stand) you'll then be able to check for any latteral play in the chain and links. The chain should resist being flexed sideways. One thing to keep in mind is that although you take good care of the bike, the PO may not have and the chain is a commonly neglected item.
Yes you are right when i purchased the bike the chain looked like the swamp thing. I cleaned it up along with the rear sprocket as well. I try to keep a practice of cleaning/lubing the chain every 1000 miles
Wow, seriously. I've never been in there. Thnks for the pics! Do you just go and hop intot he garage with a camera every time someone has a question, or do you actually have all these pics on hand, ready to go? It seems like you've got a ton of them.
Alright so i came home today to see what is gonig on with my chain, and here are the results.
Before i touched anything at all.
![Name: SANY0694.jpg
Size: 145.2 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62181d1501323122-great-way-ruin-my-day-sany0694.jpg)
As i was removing the fairing this fell out of the bike
![Name: SANY0695.jpg
Size: 170.8 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62182d1501323122-great-way-ruin-my-day-sany0695.jpg)
What the hell is in there???
![Name: SANY0697.jpg
Size: 112.0 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62183d1501323122-great-way-ruin-my-day-sany0697.jpg)
How in the heck did a towel get in there?
![Name: SANY0698.jpg
Size: 149.5 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62184d1501323122-great-way-ruin-my-day-sany0698.jpg)
![Name: SANY0699.jpg
Size: 121.6 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62185d1501323122-great-way-ruin-my-day-sany0699.jpg)
It was a pain in the butt to remove the wound up towel
![Name: SANY0701.jpg
Size: 147.0 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62186d1501323122-great-way-ruin-my-day-sany0701.jpg)
The cover looks good but the metal bracket in the lower picture is bent
![Name: SANY0702.jpg
Size: 147.0 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62187d1501323122-great-way-ruin-my-day-sany0702.jpg)
![Name: SANY0703.jpg
Size: 179.5 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62188d1501323122-great-way-ruin-my-day-sany0703.jpg)
Also the pressure broke the casting where the bolt goes.
![Name: SANY0708.jpg
Size: 113.2 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62189d1501323122-great-way-ruin-my-day-sany0708.jpg)
So it sucks, i have no idea how a towel got in there at all.
Any ideas on how to fix the cracked casting for the bolt.
Also the countershaft sprocket only have on marr mark on one tooth
Does the warrant a replace??
Thanks
Thanks
JohnnyX
Utter05
Holly crap batman! That's a first for me. I have to believe the towel was on the bike somewhere before you left the garage. I can't see it getting picked up from the street, besides you would have seen it as you rode down the driveway. No matter, I think it's time for a chain and sprockets. The front one surely needs replacing. Go ahead and remove the sprocket and look closely at the areas I'm pointing to in your photo. The teeth are hooked pretty good. Normally the rollers of the chain ride completely down in the bottom of the teeth. As the chain stretches, it rides up on the teeth higher and higher. It puts greater strain on the chain and the sprocket teeth. The chain doesn't actually stretch, but the pins that hold the links together wear on the inside which allows the links to move further appart. It's time to go new.
Size: 77.6 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62168d1501323108-great-way-ruin-my-day-sany0708.jpg)
Since you're going to be looking for a new chain, let me drop a hint... there is something to be said for purple...
![Name: DSC02220.jpg
Size: 42.8 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/62169d1501323108-great-way-ruin-my-day-dsc02220.jpg)
OMG. I've seen yellow, but never purple. That would match my bike perfectly (Yellow\Purple 96 F3). Does a Yellow/Purple chain exist? I've been kicking around the idea of upgrading the sprockets, so this would make sense to throw in. . .
Are you able to get the chain back on it ? If so, that would help hold it still. Putting it in 6th gear will also help. It's not a left handed thread in case you're wondering. An electronic impact wrench is not nearly as powerful as a pheumatic one. Is the problem that you can't put enough torque on it, or that the enging spins ?
