Gasket Sealer
Old Mar 13, 2006 | 10:51 AM
alm70's Avatar
Default Gasket Sealer
I'm putitng my carbs back together and at the top of the carbs under the air funnels is a small gasket. When I took the parts off the gaskets just kind of dropped out. When I put this back together, should I use some kind of gasket sealer on the gaslets when I put it back? Maybe an elementary question, but I just want to do it right.
thanks in advance...
Old Mar 14, 2006 | 12:28 AM
transamlt1man's Avatar
Default RE: Gasket Sealer
If the gasket is still in good shape I would just put it back in. Most of them in carbs are o-rings that can be reused. Either put the old one back in or buy a new one... u will have to make that choice depending on its shape.
Old Mar 14, 2006 | 03:58 PM
alm70's Avatar
Thanks...the gaskets..or should I say o-ring's look fine. I was probably using the wrong term. I don't believe I need to buy new ones since they look fine.
I was just concerned about possibly putting something on them before putting back...thanks again.
Old Mar 14, 2006 | 08:48 PM
When I cleaned my carbs I used the old ones. I rarly have to replace them unless the bike is very old that im working on.
dsenk48
How-To: Mechanical
Sep 22, 2013 08:09 AM
kahlilj
Jun 8, 2013 01:36 AM
dgk600f4i
Aug 1, 2012 08:47 PM
Jeff0044
Jan 27, 2011 10:04 PM
some guy #2
Jul 30, 2007 09:56 PM
