Fuel Pump
RE: Fuel Pump
It will pulse,then vibrate like a cellphone when almost empty.When it's primed,it won't make a sound.
The F3 needs a little help with fuel flow,but not much,maybe 4 psi.This is due to the ram air.
F2s are gravity fed.My F3 was,until I started doing long pulls in top gear and it would shut off.In went the fule pump,and away went the problem and away I went to my first win of the season.
RE: Fuel Pump
ORIGINAL: MickyWiz
All the CBR600s have pumps.
To answer the original question, I presume that some fuel would be able to pass through the pump even if it wasn't working, but I am sure as soon as you gave it any kind of throttle the engine would starve of fuel and possibly even shut down. I guarantee if your bike is running well and you have the pump installed, your fuel pump is working fine. but as someone else said, the F3 would run fine without a pump (gravity fed) untill you achieve high speeds and the ram air is pushing in a large amount of air, that the pump needs to match with enough fuel.
Kopi Ko
10-01-2019 08:29 AM
