fuel delivery problem ?
Old Jan 7, 2007 | 08:14 PM
ajoin4's Avatar
Default fuel delivery problem ?
I have a 95 f3 I picked up cheap but butched.The problem is the evap system and the fuel can mounted under the swing arm was removed. the fuel lines run from the tank to the pump to the carbs,the bike runs great through 1st gear ,when you hit second gear it feels like it's starving for gas and sounds like a v-twin. I've also tried running the fuel line straight to carbs and bypassing the pump but the result is the same.
ANY HELP OR IDEAS WOULD BE GREAT...
Old Jan 7, 2007 | 11:51 PM
blkpitbull's Avatar
Default RE: fuel delivery problem ?
Have you tested the pump itself? Saying it does the same thing with or without the pump inline sounds like the pump isnt working. Could be carbs WAY out of sync, fouled plug/s. Check the pump!
Rockshoxtora
Aug 12, 2010 03:58 PM
berga1
Oct 25, 2009 01:36 AM
cbr007
Sep 10, 2008 03:20 PM
89cane
May 14, 2008 09:24 PM
tr2
Sep 21, 2007 02:18 PM
