front brake question
Old Sep 16, 2008 | 10:37 PM
ff_emt_Chris's Avatar
Default front brake question
Just brought my new bike home. 95 cbr f3. Was looking it over and noticed that the front brake calipers move some front to back. The bracket off the forks is tight. Is this usual?
Thanks
Old Sep 16, 2008 | 11:34 PM
F3Rider's Avatar
Default RE: front brake question
are you saying your caliper moves in and out when your bike is moving?
...if this is the case your rotor has a slight bend in it....my bike had the same problem...and my caliper kept moving in and out everyime that part of the rotor went through the brake pads.
...the slighest bend in the rotor can cause this
Old Sep 16, 2008 | 11:58 PM
not in and out but like it twists on the bracket. I can take my hand and move it like im turning a dial on the radio.
Old Sep 17, 2008 | 12:01 AM
soccer13pro2007's Avatar
sounds like you're missing a bolt, there's two that should be in there
Old Sep 17, 2008 | 09:49 AM
its not alot of movement like maybe 5 degrees max. I will check both bolts but they appear tight.
coalminer frank
F2 Tech
Aug 2, 2013 11:06 AM
TyStrand
Aug 13, 2011 04:19 PM
Pappasquirrel
Nov 29, 2010 11:05 PM
camaropower
Dec 3, 2008 08:09 PM
Jon Boy
Feb 27, 2007 01:06 PM
