fire
Old Sep 6, 2023 | 05:07 PM
wts8612's Avatar
Default fire
I have a 98 f3 carbs have been cleaned no exposed wires no gas leaks but when it warms up it catches fire I don't know why this is happening could someone please help
Old Sep 6, 2023 | 05:50 PM
rockpool's Avatar
Where does it "catch fire" - you need to explain your problem better.
Old Sep 6, 2023 | 07:42 PM
wts8612's Avatar
it's around the carbs but it doesn't seem to be backfireing through them it idles and runs fine till it catches fire
Old Sep 7, 2023 | 03:58 PM
rockpool's Avatar
They must be leaking gas then - there's no other explanation.
Old Sep 7, 2023 | 10:28 PM
dannoxyz's Avatar
Did you replace all rubbers in carbs? Float-bowl seals, float valves, pilot-screw O-rings, fuel-rail O-rings?
There are fluorescent dyes you can get to put into tank. Then use UV flashlight or fluorescent bulbs (not incandescent party light), that will make leaks glow bright green to show where it's coming out.
Slqven
May 30, 2023 04:02 PM
tvoburner
Mar 8, 2012 08:53 PM
iluvdalaydees
Jul 26, 2006 11:28 PM
reno55
Mar 31, 2006 11:14 PM
sup_uni
Mar 25, 2006 07:31 PM
