F4 Fork on a F3 - need Help
Old Aug 17, 2011 | 06:02 PM
dk275's Avatar
Default F4 Fork on a F3 - need Help
On my F3 the rebound adjuster is jammed. Its cheaper to buy used forks than to buy new adjuters (about $170 each). I want to research putting a F4 fork on my F3. This would give me bigger calipers and a compression adjustment.
I need someone who owns a F4 to measure the length of the fork from the axle centerline to the top of the fork tube (not including Preload and rebound adjusters).
The reason I want to know the length is that I want a fork with the smallest geometry change.
I know the triple tree would have to change.
Thanks
Old Aug 17, 2011 | 07:39 PM
gotcbr's Avatar
I've already done this for you in the same post you made in the F4 section here...
https://cbrforum.com/forum/cbr-600f4...ion-f3-129669/
Old Aug 18, 2011 | 03:32 PM
dk275's Avatar
I don't see it. I see a seat conversion and a f4 vs f3 subframe.
Old Aug 18, 2011 | 05:24 PM
gotcbr's Avatar
Click on "F4 fork Conversion on a F3" in my post above. It takes you to the thread you posted in the F4 section, which is the same as this. You'll find your measurement there.
FlyWheel
Sep 18, 2012 07:49 PM
driyac
Jul 11, 2010 02:40 AM
civicblade
Apr 23, 2009 08:24 AM
WhiteHawk
Mar 17, 2009 10:17 AM
crx2cbr
Jul 6, 2008 01:56 PM
