F4/f4i/RR from other Hondas????
Old Oct 10, 2006 | 07:25 AM
Nelson F3's Avatar
Default F4/f4i/RR from other Hondas????
i've search on here and i couldnt find what i wanted.
3 Questions:
1. are the 3 spoke RR/F4/F4i lighter than our 6 spokes F3 wheels even though they are .5 wider and half the spokes and newer design? or would they be the same weight?
2. if i got a set of f4i/RR rims would they fit without modification? Still using my sprocket and brakes of course.. do these bolt on?
3. will they clear the swing arm without rubbing? i have a 180 tire on my F3 currently so i don't see any problems.
Reason why i ask is i can get a good deal on a set, i like the 3 spoke design, my rear tire is a 180 so 5.5" width suits it better, and i want to either chrome or powdercoat them. and i rather buy a set, not have downtime on my bike due to the process and be a patient customer lol
TIA Nelson
Old Oct 14, 2006 | 03:41 PM
Nelson F3's Avatar
Default RE: F4/f4i/RR from other Hondas????
anyone?
Old Oct 14, 2006 | 06:20 PM
Ryder M's Avatar
whats wrong with the rims already on your bike , just have them powder coated , and alls running a larger rear tire does is slow the bikes aceleration and turning , larger tire equals more rotating mass = less power , and f3's need all the power they can get
Old Oct 15, 2006 | 09:13 PM
Nelson F3's Avatar
i like the look of 3 spokes and i can get a set for cheap. also i can get them powder coated without having to take the rims off my bike and then have to take the tires off. plus i want 2 sets.
so to answer my question will they fit???
Old Oct 16, 2006 | 03:46 PM
Triax's Avatar
I'm pretty sure they don't fit, especially the rear wheel. I think you would have to change your swing arm over to the 600rr or something
Old Oct 16, 2006 | 04:34 PM
jbreit's Avatar
I was wondering the same thing. My F3 project needs a back wheel, and I found a VTR wheel cheap....might buy it just to find out.
No idea on the front. You can make anything fit...with custom spacers. Honda uses the same bearing size without exception on the 600's..F1 to F4i, and VTR, some 900's, Blackbird (600rr isn't on my bearing list)....but the brake rotor offset, speedo drive and fork spacing all have potential for differences.
The rear I can tell you what I do know. the F2/3 and F4 and VTR and 1996-1999 900rr's use the same axle diameter (though there is a change in the bearing/seal kit in 1997 on the F3). They also use the same rear rotor (I think honda has basicly 1 rear rotor for every sport bike). I don't know about the cush drive, but there are some sprocket overlaps.
I am sure the 600rr wheels are lighter....the front for sure and most likely for the rear even with the width difference....does that make them better..?..if you track your bike, that extra 4-8 ounces might make a difference in an s-curve, but is your riding at that level anyway...? Sure make them easier to clean....I hate cleaning the F3 spokes. If you have a completely bare wheel, you'll find the aluminum portion is pretty dang light...the bearings/seals/rotor weight more than it.
A 180 tire on a 5.5 rim will be a fuzz wider than a 180 on a 5.0 rim. But I think I heard of 900rr rear wheels on F3's a lot.
Old Oct 17, 2006 | 12:31 AM
Nelson F3's Avatar
yeh i like the 3 spokes for a lot of reasons.. easier to clean, when polished or chromed the fatter/wider spokes are more appealing, not many F3s if at all with 3 spokes, wider and possibly lighter.
the 93-97 900RR rear wheel is 17x5 in rear and 16x3.5 in front. so the rear is the same as the f3 and they are 6 spokes also. so that is 2 negatives there.
so i wish someone could tell me if the f4/f4i set of wheels fit the f3 with no modifcations except to the brakes and sprocket.
Old Nov 14, 2008 | 05:14 PM
Cavinder's Avatar
at most you may have to get some spacers made up. then after that just swap your parts from the f3 wheel over and it should work just fine.
Old Nov 14, 2008 | 05:43 PM
ynks4evr's Avatar
WOW.... suuuuper bump
Old Jul 16, 2009 | 02:24 AM
bdjuju's Avatar
Registered Users
Heh. That just has to make me laugh.. 100hp in a 400lb bike and they call it underpowered? As the lolcats say, "UR DOIN IT WRONG"
Kids, today.
XxCBR_SILVERxX
Oct 23, 2011 03:47 PM
Ryda Girl
Mar 11, 2011 07:31 PM
aerialspider
Jan 24, 2011 04:49 PM
svek
Jul 8, 2008 10:28 AM
rocket954
Aug 19, 2005 05:06 PM
