F3 stalling problems
Old Jan 29, 2012 | 10:09 AM
djkain's Avatar
Default F3 stalling problems
I am about to pull my hair out on this one. I just replaced the R/R with the FH012 R/R using the instructions that came with the Regulator and everything seemed to go smooth. Bike starts up and idles perfect around 2k RPM's throttles good but when I took the bike out for a ride I noticed the problem. When the bike gets to about 6k RPM's it starts loosing power and slowing down like the front brakes are in all the way. When I pull the clutch in the RPM's drop all the way down to under 1k then come back up. The bike has a brand new fuel pump so I don't see that as the problem. I put new gas in 91 octane. Everything ran good till the stock R/R would not charge the batt and the bike died. Please need help Thanks
Old Jan 29, 2012 | 01:11 PM
djkain's Avatar
I figured it out. when I put the gas tank back on it disconnected the air hose going to the valve assembly.
tmoore
F2 Tech
Nov 22, 2011 10:15 AM
ginnymack
Jun 25, 2010 07:43 AM
Crashman
May 10, 2008 09:05 AM
Crave
Mar 24, 2006 11:08 AM
