F3 running issue need help b4 i sell it
Old Jul 13, 2017 | 03:41 PM
Flet3000's Avatar
Default F3 running issue need help b4 i sell it
So my f3 has never run properly since i got it, it will start and run fine for a while but then with no warning will start to run realy lumpy and my m8 said it starts smelling of fuel when hes following it. Ive had carbs apart and cleaned and replaced coils and plugs but it still does it. Im thinking it could be electrical but unsure what to check, any ideas?
Old Jul 19, 2017 | 12:41 PM
Kevin Hamilton's Avatar
Sounds like it's running rich. Possibly a clogged/ restricted air filter or the P.O. could have rejetted it. Are you SURE it has stock jets? I believe stock is 135 138 138 135 mains, 40 slows.
Also check to make sure your choke cable is routed correctly and relaxing fully when disengaged.
Edit: if you're riding at altitude it could also cause an enrichened mixture.
sohcman
Jun 16, 2010 06:18 PM
CBRfenatic93
Jan 29, 2010 02:32 AM
folkenfinel
Aug 17, 2009 05:35 PM
pfsnsd
Jul 30, 2008 06:31 PM
