F3 rattle/banging help?
Old Mar 13, 2014 | 07:25 PM
CBRrider94's Avatar
New Member
Default F3 rattle/banging help?
Hi all.I picked up a 98 F3 on Tuesday. I was hoping for some advice from you guys and gals.
I started hearing a rattling sound at around 2500 revs. It's since changed to a clunking/banking sound. Any ideas?
The MOT which was done the same day as I bought it showed slightly loose drive chain and slightly worn rear drive sprockets as advisories. Could this be the cause?
Thanks again.
Calum
Old Mar 14, 2014 | 04:41 AM
jackojeff's Avatar
Thanks again.
Calum
were is the noise coming from?
put bike on stand and stand to the left then stand to the right
you then need to move your ear slightly behind the head and slightly infront
here the deal if it the the left of the motor its to do with starter/charging system
if its to the right its cam chain tensioner
if its both it could be either or exhaust valves
if its to the right and quieter behind the head but louder infront i would say exhaust valves if not i would say cam chain tensioner.
its hard to explain but anything over 25k generally get a new cam chain and tensioner for safety reasons
Old Mar 14, 2014 | 08:37 AM
CBRrider94's Avatar
New Member
Cheers. It was the drive chain. Had a look at it in the light of day, chain was really loose, I've tightened it up and I've got a new one and new sprockets on order.
There is a sound similar to what others have described on other threads from the right, I think it's the CCT. The bikes done 24000 and still running the original so may need swapping out too. What's the best one to go for? OEM, APE?
Thanks again
Old Mar 16, 2014 | 10:23 PM
josiahafelix's Avatar
I did an ape, installation is nice and easy, I have not however changed the cam chain. Jackojeff, I'm assuming my cam chain is stock, 35k miles, should I be replacing it?
Old Mar 17, 2014 | 04:27 AM
RedBaron's Avatar
Go with A.P.E, those stock tensioners are absolute rubbish.
Old Mar 17, 2014 | 04:42 AM
jackojeff's Avatar
up to you, i had stock tensioner and stock chain until 45k when i put an ape on and all was fine until i de-commissioned the motor as it was burning oil and had a wrecked gearbox
might be worth it just to be on the safe side
wes 17
May 4, 2013 09:39 AM
Shadow
Jun 25, 2012 11:05 AM
cbrsix
Dec 3, 2008 09:16 PM
specializedfuji
Nov 20, 2008 11:52 AM
EsteRollo650
Jan 15, 2008 06:49 PM
