F3 to F4i Gauge Swap
#121
#122
well then its working fine.
if you have a main power line from the battery to the power lead for the gauge cluster, and it's still staying a 2k, then you might have to open it up and see if something is messing it up physically inside, because it shouldnt matter where the needles is off, it should reset itself every time you turn it on.
#123
#124
#126
#127
Did you ground out the pink wire? Around 7k is when I noticed my bike would bog before I grounded it. Just a thought....
#128
#129
To anyone whom has successfully done the 900rr thermo swap. When you turn on your moto does the light still pop up and you get a - on the digital readout? My bike isnt currently running so I dont know if it will work properly when I actually start it or if this is normal. Please and thank you
#130
yeah the light is going to pop up and a dash will be present on the screen until the bike is running...once the bike is running the light will go out..don't worry about the readout staying as a dash(got me at first too) the readout will stay a dash until the sensor reads roughly about 95 degrees then keeps up from there
