F3 to F4i Gauge Swap
has anyone done this gauge conversion?....how hard?......what year F4i gauges did you buy?.....im thinking of doing this, this summer. Any input would be great!!!!!!
.....i read somewhere about having to make your own custom brackets to mount the new cluster?
Thanks alot every1
Thanks alot every1
http://cbrworld.net/forums/thread/219055.aspx
i made a custom bracket before i did the f4i fairing swap. love the new guages. real easy, except putting that new sensor in for the temp was a pain in the butt. if you have the right tools itll be easy. i believe a 1/4 rachet set with swivel will do it. i only have 3/8s so it was a bit of work.
also the guage is a bit off, but now it doesnt matter anyways since i did the sprocket change. speedohealer is on the way anyways
iirc the year guages is gonna be any f4i
if you dont put the 900rr temp sensor, itll read overheating all the time. 900rr temp sensor put it right on dot
Interesting. Which I've always wondered about putting in an F4i engine(Or even a 600rr) into an F3 then turboing for a supersleeper. And I'd like the gauges to match everything up. This will of course be after I get another bike.
Which to clarify would the F4i Gauges match up well with the F3 upper fairings or do you have to put on the F4i body.
ORIGINAL: krayton
K....ill to have to check it out. Now only if i can find a F4i gauge cluster for a decent price......ill check out ebay but i doubt it
Someone said that you need to put the temp sensor from the f4i but others say from the 900rr, what or witch one is it can some one help me out because im about to do the swap on my bike and want to do it right. thanks
900rr is a direct screw in. people originally put the f4i one, but a few members found the 900rr one works perfect.
so 900rr for sure. dont have to do anything special. if you went with the f4i, youd have to tap your existing hole, or put a inline radiator hose adapter
If its an ez install....then im gonn start this project as soon as i can find a resonable F4i gauge cluster. So thats all you need is the 900RR temp?....everything else just plugs right in then?
