Exhaust removal
Old Sep 5, 2009 | 01:17 PM
freakyb's Avatar
Default Exhaust removal
I took off all six nuts/bolts that mount the exhuast to the engine. The brakets on the outside came off/down the pipe without a problem. I can't get the pipes away from the engine. Could it just be stuck? I've also removed the bolt that holds the pipe to the underside of the bike. I grab both sides and wiggle -- it has a slight play but won't come away. My temper has gotten me into this situation, and I'd rather not break something else
Its a 98 if that gives you any idea of how hot/old the fittings could have gotten.
Old Sep 5, 2009 | 09:11 PM
millertyme's Avatar
dont quote me, as i have been known to be wrong once before, but i just installed the pipes on my 98, and i noticed that the pipes hung on inside the exhaust ports. this held the pipes up, which was nice, as it allowed me to connect the bolt to the frame under the engine. as for the parts you removed, the six nuts, one bolt to the frame under the engine, and the hanger on the can, you got it all. the only thing i could see, and i would never have suggested it if it just didnt happen to me, is that the pipes could be catching in the exhaust port.
BTW, i am using the original header.
Old Sep 5, 2009 | 09:50 PM
freakyb's Avatar
Hmm - that might explain the reason they don't fall right off -- if there is a lip that they get caught on. I sprayed some PB blaster, might fidgit with it tomorrow morning.
itscolinbro
Aug 23, 2013 02:39 PM
rigbyj05
Mar 14, 2013 09:09 AM
954RR RH
Nov 30, 2008 10:07 AM
gorilla_biker
Jan 5, 2007 11:54 PM
sirlimpzalot
May 10, 2005 11:26 AM
