engine swop
Old Jan 2, 2008 | 07:17 PM
Big Bad Billy 1's Avatar
Default engine swop
will a 95' 900 motor go into a 95; 600 fram. what do i have 2 do.
Old Jan 2, 2008 | 08:24 PM
buddah's Avatar
Default RE: engine swop
I think it's been done by a member of this board already---not 100% sure though but yeah it should work I think
Old Jan 2, 2008 | 08:40 PM
Frankenstein's Avatar
Yes it will, Thewiring harnessis different but can be modified to work.Theairbox and CPUaredifferent. The Radiator has different mounts butthe F3 unit should be fine. The later curved F3 radiator isefficent due to its shape. The 900 radiator may have more capacity and area but I don't think so. Plus keeping the one you have is cheaper. There are other tricks if it is getting hot anyway.
The CPU's are different on the 2 bikes and but you should just have to swap them out. I'm not sure about that though and it would take closer examination.
Old Jan 2, 2008 | 10:25 PM
rsp919's Avatar
CBRF 2009 AOTY !!
It can be done. Both Bindelsf2 and myself have done it. I have a 98 in my d4 frame. search the forum and you can find all the info you need.
mbooth1
Dec 26, 2011 12:03 PM
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
nasty
Nov 27, 2006 03:14 PM
