electrical problem with gauge
Old Aug 24, 2010 | 12:53 PM
nuttynu's Avatar
January 2012 AND 2013 Ride of the Month
Default electrical problem with gauge
i have the f3 with the f4i gauge cluster, so today i was putting in my side flush mount and when i tried to wire it up it wont work , then suddenly i turn the key on and now the gauge wont even turn on....did i blow up the fuse or something if there is one and where would that be located at? the bike will still start but just that my running light is dead and the gauge is dead too, the time still show. but what did i do?? any help will be awesome.
Old Aug 24, 2010 | 01:27 PM
kerosene's Avatar
Sounds like the fuses are blown... check on right hand side (throttle side) there is a fuse box... check the fuses there.
How did you connect the gauge? did you solder the cables together or did you use the male/female connectors?
Old Aug 24, 2010 | 01:39 PM
nuttynu's Avatar
ill check the fuse but as for connection it was done by the previous owner, but to me it doesnt look solder
Old Aug 24, 2010 | 01:49 PM
kerosene's Avatar
if the fuses look good, then check the wiring make sure that everything is connected... that's why I always solder ALL my cables, so the connectors don't come loose.
Since your clock works that means you're getting power... if your headlight doesn't work, I'd venture to say headlight fuse went out
Old Aug 24, 2010 | 01:55 PM
nuttynu's Avatar
ahaha what a no brainer, thanks Kerosene, its was nothing major, jus a blown fuse like u said. i know it had to do with the fuse , i just forgot where the fuse box was. ahaha. well thanks. ima go ride now.
Old Aug 24, 2010 | 01:59 PM
kerosene's Avatar
not sure why you blew the fuse wiring up the flush mount. Have fun, ride safe!
Old Aug 24, 2010 | 02:29 PM
nuttynu's Avatar
i have no clue, i think i wire it vise versa
Old Aug 24, 2010 | 02:42 PM
kerosene's Avatar
wouldn't blow a fuse, it just wouldn't work... unless you bought some cheap flush mounts that don't have resistors... if you can add 100ohm resistor to the turn signals (just in case.)
if you don't know how... cut the positive cable on the turn signal (somewhere in the middle) solder 100ohm resistor, tape it with electrical tape and you're done.
kwood
Jun 1, 2020 09:53 AM
F2Supersport
Mar 14, 2011 05:40 PM
aguara
Jun 22, 2010 04:47 PM
chinakid245
Sep 1, 2009 01:19 PM
vfrman
Nov 16, 2008 10:06 AM
