Electrical difficulty
Old Jan 12, 2006 | 06:17 PM
Power2weight's Avatar
Default Electrical difficulty
So the bike stranded me this morning, sucks, its such a nice day.
It ran fine for about 15 miles, I stoped at a gas station and when I turned the key the lights lit up like always, press the starter, it turns over once and all the lights die. Wont turn over agian.
Push started it, and it started, idles fine but all the lights are really weak, the tach jumps all over the place, the engine sputters and backfires when I try to rev up, and the speedo goes up with the tach not with road speed.
I'm thinking its the voltage rectifier thing that always goes?
Old Jan 12, 2006 | 10:37 PM
DTHWSH69's Avatar
Default RE: Electrical difficulty
Could also be a weak battery. I have read that cranking/running with the weak battery could also burn up the regulator.
Old Jan 12, 2006 | 10:44 PM
pupdog_88's Avatar
check to make sure your battery cables are tightly screwed on, if they are then check your battery with a voltmeter and make sure you got a good battery if it's around 12.5 volts than your battery is good, it all that checks out than it might be a rectifer
Old Jan 13, 2006 | 02:47 PM
so where is a good place to buy the voltage regulator online?
did a search and cant find it
I wish I had another bike for times like these
also is a rectifier and regulator the same thing?
Old Jan 14, 2006 | 11:50 PM
DTHWSH69's Avatar
Ebay always has at least two different brands ranging from 59 to 89 bucks.
Old Jan 23, 2006 | 05:36 PM
denhou1974's Avatar
Make sure you get the one with integrated cooling fins. My stock VR did not have them (97F3).
http://cgi.ebay.com/ebaymotors/ws/eB...category=35594
Old Jan 26, 2006 | 05:07 PM
danger2otherroaduser's Avatar
Take the battery off the bike and charge it to full then leave if off the bike for a day or two. Check the batterys voltage after this period has elapsed, if the battery reads 12-13.8 volts sounds you need a new rectifier/regulator if the battery has lost the charge (lower than 12v) change the battery as it is faulty!
If you have an alarm fitted, in most cases its a discharged battery. Charge the batterry and try again.
i had the same fault last year i need a new battery and regulator/rectifier.
thanks
chris
dtoru@tiscali.co.uk
ken12
Apr 5, 2008 02:08 PM
Exile
Jan 20, 2008 02:28 PM
jmanng
Nov 21, 2007 09:06 PM
ocrider26
Aug 24, 2007 07:50 AM
Diabo
Jul 23, 2006 03:07 AM
