Driving me crazy
Old 09-28-2010, 04:05 PM
F3LUV's Avatar
i have deeply been looking into fuel issues. it may be time to pull the carbs and see what the hell the previous owner put in for jets. i do not smell fuel while it is idling and like i said before the bike will sit there and idle perfect for 45 minutes or longer if i want it to. and this bike does not have a fuel filter on it. already looked into that. i have the bike set to idle at 1600 rpms. thats where the manual wants it and thats where i idle mine
Old 09-28-2010, 05:27 PM
F3LUV's Avatar
ok so for an update. i fired the bike up after sitting all night. bike fired right up with no issue. i mixed in about 3 ounces of GM fuel system cleaner with a full tank of gas. i use the stuff alot at work and its some pretty potent stuff. i was suspicious of dirty carbs etc etc.rode the bike around cold with no real issues except it would slightly cut out in high 2nd or 3rd gear. around 8000 rpms. but it would still run. did the same thing warm but not as much. rode the bike for a few miles with no issues. so hopefully this is the start of a fading issue. such as horrid dirty carbs. lets cross our fingers and pray.i will keep u guys further updated. thanks for the help
Old 09-28-2010, 05:41 PM
kerosene's Avatar
well if it's dirty carbs you can use seafoam, just not too much as it can make **** worse (1/4 of the bottle max) it'll clean it out, not sure if better/worse than GM Fuel SC but I don't use anything that's branded GM :P
Old 09-30-2010, 05:38 AM
Bus's Avatar
Bus
Bus is offline
Sounds like the tank vent to me. Next time it dies, open the fuel tank, then start (if you have another key. If it starts right up, you have a plugged vent.
Old 09-30-2010, 11:02 PM
F3LUV's Avatar
im deff thinking i had some dirty carbs. i tried opening the tank before when it happened and it made no difference. and im deff going to go get some seafoam. but the gm fuel cleaner was all i had and i judt grabbed it from work. seemed to work good tho.lol. bike is running ALOT better. or im just happy its even running.lol. and kerosene.... i take it your not a fan of GM?. haha
renxwar
07-18-2020 07:33 AM
robbiebgraham
The Hurricane Saloon
11-07-2013 10:42 PM
codyw2012
07-04-2012 08:55 PM
hellbulit
04-28-2009 09:45 PM
lostnawave
05-16-2007 09:30 PM
Quick Reply: Driving me crazy
