Drive shaft oil seal?
Old 04-09-2008 | 02:16 PM
bond67's Avatar
Default Drive shaft oil seal?
well long story short i bought a cbr 600 f3 off a guy who said it was just leaking out of the shft shaft seal... well that wasnt the case. its actually leaking out of the seal behind the sprocket. ive been told that you have to split the case in order to get it replaced. i was quoted about 1200 at some of the shops around here and have a friend of a friend saying he'd do it for 700. is there anyway this can be sealed up any or maybe some other way around this.. i hate that i got screwed like this and not sure how to go about it. the guy isnt going to do anything about it. also what is this guy talking about
https://cbrforum.com/m_377172/tm.htm
could there be something wrong with the seal on the sprocket, the rubber on the back of it doesnt look so good... but it doesnt really look like it has anything to do with the other seal, unless its really ate up.
Old 04-09-2008 | 02:49 PM
dusterdude's Avatar
Default RE: Drive shaft oil seal?
if this seal is in like the sohc 750`s,all you need to do is turn a small sheet metal screw into the metallic portion of the seal and pull out,then tap the new back in.if not,i havent a clue.good luck
Old 04-09-2008 | 03:43 PM
bond67's Avatar
well aparently this has a lip on the back of it and needs to be taken out and installed from the back side of the case. what a PIA.. i dont know why they didnt make it easier to replace..
Old 04-10-2008 | 08:52 AM
dusterdude's Avatar
wow,that sucks.i think engineers should be made to work on these things when they design them,then they might do things different.
Old 04-10-2008 | 11:17 AM
marc0011's Avatar
I've never split the case of an F3 but I was looking it over and it doesn't look so bad. I think the worst part is getting the engine out of the bike. It's a lotta work but not impossible.
Old 04-10-2008 | 06:19 PM
kjohnson's Avatar
If you gotta go that far go ahead and rebuild.Might as well if you gotta split the cases.May be cheaper to buy another motor.
I have an extra F3 motor if you want it.
Old 04-10-2008 | 07:04 PM
bond67's Avatar
how much?
Old 04-11-2008 | 12:05 PM
kjohnson's Avatar
600 plus shipping.Low miles (about 6k) 98 motor.I have a plastic sealedcase to ship it in.Where you located?Im in Atlanta.
Johnny34
F2 Tech
14
03-13-2023 01:08 AM
tomttt
08-18-2012 05:57 AM
mxnoah418
04-12-2012 10:15 PM
craywm
02-21-2011 06:38 AM
sandtown929
08-01-2007 07:25 PM
Quick Reply: Drive shaft oil seal?
