Direct Air induction
Hi, everybody!
I'm a new member of this forum from Russia, St. Petersburg. So, nice to meet all of you!
I would like to ask you a question about Direct Air Induction System on my F3.
The thing is that I had an accident with my bike, and as the result all the fairings is damaged. So I'm turning my bike into a Streetfighter. As it has this D.A.I.S. mounted on it and doesn't seem to look great on the bike without fairings I'm thinking about removing it.
So are there any problems with that? Can I just remove it and forget about it or should I make some adjustments? And will there be any differences in bike performance after removing it?
Thanx.
Thanx.
Hi, everybody!
Thanx.
Thanx.
Well, sure if I find out the way how to mount them without fairings I'll definitely keep it.
Probably this is the answer to my question about poor performance of the bike without gauges. As everything was wrecked I just took of the instruments. So the system won't work without the speedometer?
As everything was wrecked I just took of the instruments. So the system won't work without the speedometer?[/QUOTE]
It will work, sorta you will find that you have pretty low power once you start to rev up past 7000 rpm. Ground the solid pink wire that would be going to your cluster if you had one and you should be fine. Make sure you ground it on a unpainted surface. I attached my wire to one of the mounting clips on the radiator
There are two separate wiring connectors that should have connected into your gauges in one of those there is a solid pink wire, find it and loosen a bolt somewhere on your frame or use the silver mounting clip on the radiator and connect that wire to it.
Go out and take your bike for a spin, if it starts to bog down you need to find a better place to ground it out.
Do you have a f3 repair manual? If not search for a free download on the internet, they are all over.
